Kicker L7 in custom bandpass enclosure
2 L7 10's in a properly designed bandpass will be loud and sound good doing it
heres wat kicker recoomends for a bandpass for those 10's
have each 10 in 1 cube sealed playing into a common 2.25 cube ported area with a 42 square inch port 10 inches long
80
I am also wondering the same thing about two 15 inch L5s. I'm not going to be able to fit a ported box into my trunk (94 accord) so I was thinking maybe a bandpass box? What is the best size for that?
aaron..... you asked about a ported and were told its too big... why would you think a bandpass would work? Its a ported AND a sealed box all in one. A bandpass for 2 L5 15s would be HUGE.
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif//content.invisioncic.com/y282845/emoticons/compcrash.gif.4ecfedd515e492755e2899769e83940b.gif//content.invisioncic.com/y282845/emoticons/beatdeadhorse5.gif.5d70132dea1eb89b73bf2fdbb6027dd6.gif
if u cant fit a ported box in your trunk i wouldnt do a bandpass being that its a bigger box
80
2 10 Kicker L7s in a 6th order...........youll be happy
80
Where did you find the specs on a kicker recommended bandpass box? I wanna build a bandpass for my L7 12"
489
976
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
norcalbwlr
Bass fanatic
norcalbwlr
Lafayette, CA
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
