kicker L7 15" old school vs. new gen
I had a 12" L7, the earliest model with the grayish cone that looks like a + sign, I installed it in a big ported box made by kicker. 500 watts was fine, upped it to 800 and I tore the tinsel lead off the cone. It was friggin loud though and the coil could of taken much more.
The newest model has its tinsel leads woven into the spider and is beefier so just avoid the 1st gen.
I have seen many blown 1st gens and torn tinsel leads, Old kickers didn't have as strong of a cone either....
Rarely do i see the newer ones blow or mess up at all unless it's on purpose since i find them to be very underrated.
its not useless, just not very wise. people put too much power to them and tuned the first gens too low. the old L7s couldn't handle the lows though (very low xmax) so tinsel breakage was common. if you don't tune super low and give the 1st gen power around or under rated it will do fine
dont buy either better can be bought for the price //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hummmm the most common problems i have seen in the first gen are the surround peeling off and voice coil burnt...... sheeeshhh i alwaz thought ppl wired it wrong or somthing... now tht i know its a common problem in the sub itsself...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
761
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
enerlevel
enerlevel
asia
Lakota
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
