Kicker KX2500.1??????
ravens9322
Kickers website says that the huge 2500.1 is only 2 ohm stable. Is that true? I would have thought for sure that the 2500.1 would be 1 ohm stable. I was looking at putting one of these on a dual 2 ohm 12" soloX and it needs to be 1 ohm stable.
If you know please reply.
Thanks
Chris
That seems really strange that much amp isn't stable at 1 Ohm but I couldn't say for certain never having ran one.
Polecat would be the one to ask out of anyone on the forum.
Yea i thought it was strange also, kicker website says that its only 2 ohm stable but i was hoping it was wrong because if i cant run that then ill run 2 Infinity 1211a's to each VC of the SOLOX.
But i would really like an answer on this. lol
Thanks
Guys
well i want to put one on a solox 12" running at 1 ohm for daily. I plan on adding an extra battery but should i upgrade the alt.? and to what amp should i make it?
Thanks for the replys guys.
Chris
It's in a dodge ram ext.cab with I think a 140A alt....He's got a yellowtop under the hood and three batcap800s in the back for juice.
EDIT...He's got a bunch of video and acc stuff too, he doesn't need all that just for the amp.
yes, the KX2500's have always been 2 ohm stable, can they run lower, as Carlton and Erik, looks like they do fine...as far as juice, I'm just adding two Kinetik battery's to mine, have a ZX850.4 and a KX25001, so installing a HC1800 under the hood and an HC2400 for the system.
ravens9322
ravens9322
Lancaster, PA
lifted95blaze
michigan born
    May 14, 2026
michigan born
    May 14, 2026
