amp goes into protect when i turn it up. i turn it back down and the subs keep hitting. the ground is good, the gains are almost all the way down.
what preamp voltage are your rca outs. What size power/ground, what battery, what amp alt?amp goes into protect when i turn it up. i turn it back down and the subs keep hitting. the ground is good, the gains are almost all the way down.
Sounds like an impedence issue. What ohms are your subs and how do you have them wired?amp goes into protect when i turn it up. i turn it back down and the subs keep hitting. the ground is good, the gains are almost all the way down.
2 ohm load, stock battery and alt. 1/0 power and ground. not sure on the preamp voltage.what preamp voltage are your rca outs. What size power/ground, what battery, what amp alt?
two dual 2.Sounds like an impedence issue. What ohms are your subs and how do you have them wired?
uh oh...this is not a good sign.so the amp was doing the same thing when you had it?
http://www.caraudio.com/forum/showthread.php?t=212855
not looking good..//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gifso the amp was doing the same thing when you had it?
Yeah it *****. I just sent him a money request on paypal to get my refund. Hoping I get it here pretty soon so I can order another one from another user on here.not looking good..//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
I just find it a bit strange that we were having the exact same problem. I noticed that when the amp got here you had the gains turned down quite a bit. 2 lines below half way I believe, which is about where I have them to get the amp to play without going into protect.that was when i had the subs wired wrong.
