Kicker 500.2
This was the amp in my truck. Adult owned for one year and six months single owner I bought this new and it was never abused..Works perfectly. Just getting a bigger amp for bigger subs..As you can see in the pics this thing is flawless.I have a 100% ebay rating and will take paypal..
Birth sheet said 760
$100 obo +shipping...
Kx 500.2
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 125W x 2
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 500W x 1
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: 2 x 30 amps
Audiophile components throughout
Double-sided glass epoxy circuit boards with large copper traces
Oversized Litz wound toroidal transformers for improved efficiency
Large TO-218 bipolar output devices for higher current capacity and reduced resistance
Triple Darlington output device configuration for lower distortion and excellent sound quality
Custom-wrapped HFQ electrolytic capacitors for maximum bass impact
Precision tolerance metal film resistors and poly film capacitors in the audio signal path
Isolated dual power supplies
Fan cooled
Remote level control
Custom-tooled oversized power and speaker output terminals
PreAmp Signal Transfer (PAST) output RCA lack
Soft muting circuit controlled by the DSP
Soft start turn-on circuit for deduced startup load
Removable cast aluminum EndKaps
jbgarner12@msn.com
Kx 500.2
Preamp Outputs: Yes
Fan cooled
jbgarner12@msn.com
