Kicker Cvx
The KX 2500 would be nice, BUT you would drop it to a 1ohm load, that kicker is rate for 2ohms, I believe, it might be stable though you'd have to ask around
That kicker = a greatttt amplifier though
uhhh.......he would run it at 2ohms if he's going with the dual 2's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
4x Dual 2ohm subs = 1ohm, or am I a bloody idiot? I probably got something wrong in my head
If you go with the new ZX 2500.1 on four Dual 2ohm CVX's youll be fine, they'll get plenty of power, and the ZX's are rated at 1ohm, I found out lol
Sorry other guy confused me
Yes, that would be an excellent choice of amps
xXLiMiT
xXLiMiT
ft worth,TX
bdawson72
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
