Kicker CVR pretty underated on power handling
vehementSPL
I knew the 12's were underated some. But between the 12 and 15 looks like it goes from a 2 inch coil to a 3. The 15 is what I am maily talking about. It is rated 500watts rms but I would guess it would take about 750 to 800. Last weekend guy comes in with a pair of them on a planet audio 2250 (rated 2300RMS) on a pair of them tearing into them. I figure he is going to blow them, so I ask him how long you had them like that... he goes about 2 months I am like wtf? those are taking that amp
this if for the rx2400 planet audio. pretty sure same board
CLASS D monoblock power amplifier
· Switchable Input Sensitivity:
· 100mV-2V or 2V-8V
· Switchable Phase Shift (0-180º)
· Variable Bass Boost (0 to +18dB)
· Continuously Variable Low Pass Crossover
· Remote Subwoofer Level Control
· Variable Subsonic Filter (15-40Hz)
· Low Level Inputs and Outputs
· Heavy Duty Set-Screw Style Terminals
· Illuminated Logo
· Strapping Capability:
· Strap two amps together for twice the power
· Handcrafted in USA
Max Power (1 Ohm)
3000W x 1
RMS Power (1 Ohm)
2400W X 1
RMS Power (2 Ohms)
1600W X 1
RMS Power (4 Ohms)
1000W X 1
Signal-to-Noise Ratio
100dB
Frequency Response
20-250Hz
Dimensions:
11”W x 2-5/8”H x 20-7/8”L
OK sorry did more research. I find specs for power acoustik a3000db and same board as the 2250 according to realm of excursion
1 x 1100W @ 4 ohms
1 x 1800W @ 2 ohms
1 x 2300W @ 1 ohm
No I am aware due to impedence rise. But I never really caculate that in except for my systems I use for competitions. Either way. even if the amp is slightly overrated still figure 2000rms. 1000rms each speaker. Pretty impressive
yea i know a guy that has a power bass 3000 hooked up to a pair of 12cvr's in kicker prefab box idk wat omh load w/e it is when u buy the prefab setup and he has gains all the way turned up on the amp and been like that for over 5 months and hasnt blown them yet
vehementSPL
vehementSPL
indianapolis
helotaxi
