Kicker birth sheet...
whitemdx
Just received my kicker 700.5 from onlinecarstereo (quick shipping btw). Ordered last thursday and arrived today. Anyhow, the birtsheet state 'Total Maximum Power Output' = 972W, is it correct to assume that this is peak power?
I would assume so, given the mention of maximum power.
Someone should be along to give you a definitive answer though.
Thanks all! That's nice to know I am getting atleast 500w to my AA arsenal 12", right on the recommended RMS power.
I have a DMM so I will use it to set my gains.
sub ch rated @ 420, so I will use that to set the gain, arsenal is dual 4 ohm so i || = 2 ohm load:
V = sqrt(420*2) = 28.98V
amp 1 & amp 2 will be bridged, rated 165 x 2 @ 4 ohm bridged:
V = sqrt (125*4) = 22.36V
I am setting it at 125w b/c that seem to be the optimum setting for the 6.5 SLC's from members here on the forum. Or i can just do 4 ohm stereo (70w x 4) and leave amp 2 unloaded for future 6.5 coax for rear fill.
Can someone verify my voltage? Also, i planned on using the 80Hz @ -3 db for sub ch and 1KHz @ -3db tones for component set. Thanx.
whitemdx
whitemdx
SoCal
whitemdx
