kicker 700.5
  • 3
troy24
10
chicago
I need some help here guys, so let me know. I have the kicker 5 channel 700.5 and I am going to run 2- 4x6's and 2=6x9's and I was wondering what would be cleaner and hit harder. Now the amp is 65x4 and 400x1 in the sub channel. Would one L7 12 or 2 12 inch S series alpine hit harder?
The L7 would be the most efficent of the three, but also requires the most power especailly a 15. 400 watts is enough but you could run into distroition easily. So adjust your amp accordingly!!
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
968
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
troy24
troy24
chicago
blackgeltabs
