eclipse amps
Vorak
WI
what does everybody think of eclipse amps? I am thinking of buying the Eclipse 33230. Here are the amps specs right from the website:
  • - 310W x 2 Channel Max. Power Output at 2 ohms
    - 200W x 2 Channel 0.1% THD at 2 ohm Stereo, 20,000Hz@13.8V (RMS Continuous Power)
    - 130W x 2 Channel 0.1% THD at 4 ohm Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
    - ChannelFlex Crossover
    - Adjustable Low-Pass Crossover (12dB/octave, 50-200Hz)
    - Subsonic Filter (20Hz Fix)
    - Free-Flow Signal Circuit
    - Double-Sided PCB
    - High-Current, High-Speed Output Devices
    - High-Efficiency, High-Energy MOS FET Power Supply
    - Audiophile Grade Component Selection
    - Intelligent 7-Way Discrete Protection Circuitry
    - Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
    - Efficient Cooling with Low-Profile Heatsink
    - Multi-Mode Configuration
    - Stereo/Mono Switch
    - 2 ohm Stable Design
i am planning on powering 2 12" Type S's with this amp. Let me know what you think.
Vorak
Vorak
WI
Vorak
