Kicker 350.4 and Components
rezurxtion
Here is the problem. Dodge 2003 Ram Quad Cab with Sony Head Unit. I am running Kicker 3Way 6X9s and Kicker component tweeters in the front. The back is being filled with Kicker 6 1/2s. How do I wire these within the Amps 2/4 Ohm capability? Do I wire the each 6X9 and Tweeter in parallel in the front = a 4 ohm load or what? I just do not want to overload the amp. Thanks.
Use the crossover supplied with the components, and then just tie the fronts and rears together, that way you'll end up with a 2 ohm load.
why would you do this? if you tied the front and back together you would get a 2ohm load, but then split between the speakers. whcih will end up with a lower output then just wiring them in 4 ohm. then you will loose the front-back fade function.
i say use the crossovers, then wire one crossover to each channel at a four ohm load.
rezurxtion
rezurxtion
SOCAL
BaseSteala112
