Kicker 15" L7's
  • 1
DSGB08
10
Atlanta
Would an Audibahn A2200HCX amp work well with 2 Kicker L7 15's which run @ 2 ohm. The website says the kicker 2 ohm L7's will run at 1 or 4 ohms. The amp runs at 600x2 @ 1 ohm, 1600x1 @ 1 ohm RMS. Do you think the L7's would work well together with this amp???
762
DSGB08
DSGB08
Atlanta
DSGB08
    May 24, 2024
    May 23, 2024
