Audiobahn with L7's
DSGB08
Would an Audibahn A2200HCX amp work well with 2 Kicker L7 15's which run @ 2 ohm. The website says the kicker 2 ohm L7's will run at 1 or 4 ohms. The amp runs at 600x2 @ 1 ohm, 1600x1 @ 1 ohm RMS. Do you think the L7's would work well together with this amp??? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
DSGBO8-(-YOU WILL NEED THE DUAL
4 OHM VOICE COIL L7 SUBS)
wire each sub in to a 2 ohm load
then wire both subs in parallel for
a 1 ohm load to your amp.
DSGB08
DSGB08
Atlanta
DSGB08
firey_kimchi
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
