How much do you have?and pretty much im getting ****edcause now i gotta find an amp with more power at 4 ohms than at 2 ohms
cause the sub is not 4 ohms am i right?
which is gonna be more expensive
You dont need to spend that much on a 600 watt amp.
Yes it would workbut what about the other onesim just making sure im lookin for the right thing
if the sub is a dvc 2 ohm, then you can wire it in series which would create a 4 ohm load on the amplifier. or you could wire it in parallel which would create a 1 ohm load. http://mobile.jlaudio.com/support_pages.php?page_id=161
so your goal is to find an amplifier that will create 500watts at either 1 ohm or 4 ohms.
this is probably about as cheap as you will get brand new:
http://cgi.ebay.com/Brand-New-Profile-AP1000-2-Channel-Car-Amplifier-Low_W0QQitemZ360047466180QQihZ023QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I had one 12 inch for my second system and I was happy with even that. You will be very happy with the 15" CVR at 500-600 watts compared to your old setup at 300.I had two 12" CVRs for my first system, they definitely got the job done. I would think you will be happy with the 15" CVR.
