Keyless entry not working?
what year???
there could be a possibility that the wire's may have gotten disconnected...
can you see the brain.? dose it click when you hit lock or unlock??
dose it have a 2-3 pin plug with a green and a blue comeing from the brain?
if it dose then more then likley the keyless is hooked up just either loose connection or motor's in doors could be bad, lock unlock outputs maybe bad..
make sure the factory locks work by locking and unlocking at the factory lock/unlock switch. if they do then there is a loose connection beetween the alarm brain and the door locks
vvblazers777
vvblazers777
United States
amoffitt
