Kerfed Enclosure build for 12
Hey what formula did you use to calculate port length with that big *** flare? Oh, and fotmula to get the radius right w/ the kerf cuts.
It also gives you a port area advantage over the traditionnal slot port, right? Kinda like a horn?
Looks good
Thanks guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Looks good
And there's nothing really special I do when calculating for a flared port...I just start the length of the port at about halfway through the flared/kerfed portion.
It really helps to have google sketch-up downloaded or a program like it so you can draw it out...then find the length of the outside of the board in the kerfed portion, then subtract the length of the inside of the board in the kerfed portion and then devide that by the width of the saw blade and you have how many cuts you'll have to make to make it perfect and you then can do the math to space them across the area of the kerf to make it even //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And it doesn't really effect much other than reducing the chance for port noise and look nice
Thanxxx
well when the width of the port changes the tuning changes so u should shoot for the tunning ur using with all the port being the same size the flare just directs the air out of the port
Haha, yea...I usually sleep walk to the garage and start making enclosures, then I wake up and there's an enclosure infront of me //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif...Ive always thought it was a bit weird..
Pioneer~Saturn
Dr. Enclosure
Pioneer~Saturn
Dayton, OH
Pioneer~Saturn
