Kenwood XXV-01D Questions
Hey all, I was trying to find info on this unit on the web but I couldn't find much related to my issue. But, most of the general info I came across was on this forum, so I figured this would be my best shot.
I got this HU used a couple weeks back, and just got done installing it in my '99 Grand Prix GTP (non-Bose). I was hoping for a better rounded sound from my speakers (stock back for now, and JBL GTO528 http://www.amazon.com/JBL-GTO528-5-25-Inch-2-Way-Loudspeaker/dp/B003KN2TEE/ref=sr_1_1?s=car&ie=UTF8&qid=1450656803&sr=1-1&keywords=JBL+GTO+5.25 up front).
I know pretty much nothing about the intricacies of car audio. But, I'm read to learn. :p
So, my issue is that after installing the HU, the bass and some highs sound really muffled and distorted. My stock speakers didn't sound very good with the two old stock HUs I had in it, but I figured that was from the HUs themselves as I tried an aftermarket HU and the speakers sounded better (but that HU was old and has issues). So, when I saw a deal on this HU used I did a little research and figured it would be pretty decent and maybe improve my speakers and hopefully I could get good sound out of the fronts. Not expecting any sort of extreme bass or highs, just want to get rid of the muffled sounds and maybe have a little usable bass.
If anyone could direct me on what to fool around with in these convoluted menus that would be great.
Thanks in advance!
What source are you using?
Also, you'll want to set your crossover settings and filters as well.
The biggest improvement would to treat the doors/deaden them.
Those speakers also have a free air response of 92.1hz, you aren't going to get a very good midbass response from them.
Did you go into the menu and turn off all the crossover options?
No, I didn't really touch anything in any menus besides to turn AUX on.
What do you mean by "source".
What do I set them to? Or, is it an on/off deal?
What is the cheapest and easiest door deadening technique? Do I need to do something with my stock plastic speaker retainers? Would http://www.amazon.com/gp/product/B012B5EMGO?keywords=car%20sound%20deadener&qid=1450665099&ref_=sr_1_1&sr=8-1 work okay-ish?
Ah, okay. But, I should be able to get rid of the distorted/fuzzy sound with tweaks, correct? Would http://www.amazon.com/gp/product/B003KN2TG2/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B003KN2TG2&linkCode=as2&tag=car0cc-20&linkId=WD5EDPQCEGK6OHQV compensate in the rear for the areas my fronts lack in sound?
Thanks!
What is the cheapest and easiest door deadening technique? Do I need to do something with my stock plastic speaker retainers? Would Amazon.com: Noico 80 Mil X 18 Sq Ft Self-adhesive Foil & Butyl Mat Audio Deadening and Sound Dampening Automotive Insulation (Sound Deadener for Cars & Trucks): Automotive work okay-ish?
Thanks!
You want to run the rears more for fill but, to you could try to use them to compensate for lack of midbass.
I don't think I'd want to run a 2way, I would probably run a dedicated midbass 6x9 I think. Unless you really need more vocals. You may also be better investing in a component set in the front that provides a bit more midbass. Not many coaxials on the market that offer great midbass and midrange.
Here is a good kit that should be good enough for both of your doors. You'll want to try and seal your door up as well as possible.
Do you have these speakers amped or on deck power?
You'll likely want to cross them over around 100hz, possibly 80 depending on how much power they are getting. I don't think they'd do too well below that.
So HPF, try 80, try 100... if they can go lower, feel free to try it out.
If you're using a phone they have built in DAC's which **** almost all of the time, listening to a better source like USB or CD with high quality files (Flac, Wav, etc) will yield in better results as well.
You want to run the rears more for fill but, to you could try to use them to compensate for lack of midbass.I don't think I'd want to run a 2way, I would probably run a dedicated midbass 6x9 I think. Unless you really need more vocals. You may also be better investing in a component set in the front that provides a bit more midbass. Not many coaxials on the market that offer great midbass and midrange.
Okay, so with my JBLs as my fronts what would be the best rears I could get for ~$50 that would give good bass and whatever my fronts are missing?
I think you forgot to link or something. :p
Deck Power.
Okay, I'll try that this week.
Yup, I'll try that and see what I come up with.
Thanks for the help!
Deck Power.
Kaiser Pontiac
Kaiser Pontiac
Land of 10,000 Salted Roads and Rusty Cars.
Kaiser Pontiac
