kenwood kiv bt900 multimedia hu
  • 4
Madman11
eloy, az
Used Kenwood kiv bt900 hu
4 volt pre outs
Plays video from iPod
Have everything for it just missing remote
Kenwood's KIV-BT900 digital media receiver combines the convenience of built-in Bluetooth™ with an innovative, easy-to-use iPod® interface. Its 3" color TFT screen sports a multi-line display that makes it easy to check out song information when you're on the go. When you're parked, you can show videos from your iPod® or iPhone®, while an audio/video output allows you to send iPod video content to a rear screen when you're traveling.
Bluetooth built in
Bluetooth connectivity, designed for Kenwood by industry leader Parrot, is built into the receiver. You'll enjoy safe, hands-free calling with your compatible phone, with features like automatic muting of the music for incoming calls, downloaded phone books, and speed dialing of selected phone numbers.
iPod control at your fingertips
The KIV-BT900's volume knob operates like an iPod click wheel interface, with high-speed search keys positioned just to the right. You can jump straight into alphabet and percentage searches with the Search Mode key, while a favorites memory lets you pull up the tunes you really like without delay. The KIV-700 is compatible with your Zune player, too, offering charging and control when you plug in to the receiver's USB input.
You're not limited to iPod content — you can play music or check out pictures by connecting a thumb drive or other device to the USB input. An internal 512MB flash drive lets you store content internally.
Sound quality you'll enjoy
The KIV-900 brings a 22-watt per channel amplifier to the plate, and you can dial in the sound to match your taste with the 3-band parametric equalizer and other sound-shaping tools. The Digital E's crossover feature allows you to trim some of the lows out of your full-range speakers and adjust the low frequencies going to your sub, so your equipment plays more efficiently. If you're building a full system, the three sets of 4-volt preamp outputs make it easier to add amps and subs to the mix.
Want to keep your car's steering wheel audio controls?
In most vehicles, you can use this adapter to connect your vehicle's steering wheel controls to this Kenwood stereo. Connect a few wires, then program the adapter for your particular car and the Kenwood, and you'll retain the convenience of your steering wheel controls.
Note: Bluetooth compatibility with this receiver may vary, depending on your phone and service provider.
Note: If you're going to use your iPod with this receiver, be sure to check "Hands-on Research" for specific iPod model compatibility with this receiver or its optional iPod adapter.
Get more info on this product
Details:
General features:
digital media receiver (doesn't play CDs)
built-in Bluetooth by Parrot for hands-free calling
built-in MOSFET amplifier (22 watts RMS/50 peak x 4 channels)
3-inch color TFT display
remote control
Audio features:
DSP features settings for car type, speaker size, digital time alignment, front and rear high-pass crossovers, and subwoofer low-pass crossover
3-band parametric equalizer with 8 presets
Supreme + technology to improve upper frequency response of compressed music files
Highway Sound compensates for road noise
dual-zone audio capabilities
Expandability:
iPod direct control via USB input — cable included
Zune control and charging
compatible with Kenwood's satellite radio and HD Radio™ tuner
inputs: rear USB and auxiliary inputs
outputs: 6-channel preamp outputs (4-volt front, rear, subwoofer)
Other features and specs:
compatible with most factory steering wheel audio controls (adapter required)
Function 10/10
Condition 9/10 very minor scratches
$125 shipped anywhere in the us
Covered by me
View attachment 26540156View attachment 26540157
Pioneer avh-p4200dvdAlpine ina-w900 with bt
Sony mobile es 7457
Sony xm-604eqx
Aurasound rpm 2300
Sorry I should have said I am all set on hu's looking for Amps, speakers, and instal gear
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
526
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
781
Madman11
Madman11
eloy, az
Madman11
    May 24, 2024
    May 23, 2024
