Kenwood KAC-819
  • 2
McCraperson
hey, how do you thing this setup would be, a kenwood KAC-819
(- Maximum Output Power: 450 Watts
- Power Output at 2 Ohms, at 14.4V (100Hz, 0.8% THD): 230 Watts x 1
- Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.08% THD): 150 Watts x 1)
and two kenwood KFC-W3003 12's
(- Free-Air Resonance: 32Hz
- Frequency Response: 25Hz - 800Hz
- Heat-Resistant Polyamide Damper
- Impedance: 4 ohms
- Magnet Weight: 42.3 oz
- Power Handling: 600 Watts
- Sensitivity: 93dB
- Speaker Connectors: Gold-Plated, 2-Way SB-Type
- Speaker Displacement (cu ft): 0.141
- Urethane Surround
- Vented Voice Coil: 2-Layer
SPEAKER FEATURES
- Bumped Yoke
- Extended Pole Piece: Vented
- One-Piece Cone Design
with stinger 8ga. wiring in a ported box, and how do you think i should connect these subs to that amp?
No way in HELL I'd buy Kenwood subs. Have heard some bad things about kenwood amps frying.
I'd have to say Kenwood is a bad choice overall.
I must agree. Kenwood doesn't have anything good for making bass(except for the DB+ subs).Kenwood makes amps that work well for full range speakers and even mids and highs, but look elsewhere for bass.
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
513
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
167
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
518
McCraperson
McCraperson
Calgary, Alberta
stones
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
