Kenwood KAC-819
  • 2
McCraperson
hey, how do you thing this setup would be, a kenwood KAC-819
(- Maximum Output Power: 450 Watts
- Power Output at 2 Ohms, at 14.4V (100Hz, 0.8% THD): 230 Watts x 1
- Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.08% THD): 150 Watts x 1)
and two kenwood KFC-W3003 12's
(- Free-Air Resonance: 32Hz
- Frequency Response: 25Hz - 800Hz
- Heat-Resistant Polyamide Damper
- Impedance: 4 ohms
- Magnet Weight: 42.3 oz
- Power Handling: 600 Watts
- Sensitivity: 93dB
- Speaker Connectors: Gold-Plated, 2-Way SB-Type
- Speaker Displacement (cu ft): 0.141
- Urethane Surround
- Vented Voice Coil: 2-Layer
SPEAKER FEATURES
- Bumped Yoke
- Extended Pole Piece: Vented
- One-Piece Cone Design
with stinger 8ga. wiring in a ported box, and how do you think i should connect these subs to that amp?
No way in HELL I'd buy Kenwood subs. Have heard some bad things about kenwood amps frying.
I'd have to say Kenwood is a bad choice overall.
I must agree. Kenwood doesn't have anything good for making bass(except for the DB+ subs).Kenwood makes amps that work well for full range speakers and even mids and highs, but look elsewhere for bass.
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
464
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
McCraperson
McCraperson
Calgary, Alberta
stones
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
