quackhead
HUH?
i could not see clearly the back of the sub, but does it say one of these:8 ohms, 4 ohms, or 2ohms?
I agree with this, but if you get a 500 @ 2ohms, make sure it is 1 ohm stable, in case you upgrade subs down the road, you will have more wiring options and power available at lower impedance loads..In saying that, find one that makes 500 watts at 8 ohms that is 1ohm stable, and you will be the man!Just wire one to each channel until u get a better amp. They'll only see about 150w each but that's all you've got right now.
Find a nice mono block that does about 500 at 2 ohms.
you have two 4 ohm subs. if you wire them parallel to one amp channel, the amp will "SEE" a 2 ohm load Your KW is not rated to be stable at 2 ohms into 1 channel ( bridged to 1ch/mono).. The 8105D amp you posted a link to is rated 500w rms at 2 ohms...wire both subs to the amp parallel and it will push them with 500 watts rms, or 250 watts rms PER sub.but the mono block amp is a one channel amp can i hook it up to push both 12s at 500 watts each i was looking at this one here but its 300W x 1 @ 4 ohms not 500 watts
Kenwood - 1000W Class D Mono Amplifier with Low-Pass Crossover - KAC-8105D
Edit : @ princ3cmo dont know why you say that i will only see about 150w each caues its 4 ohms: 170 watts x 2 chan and bridged, 4 ohms: 500 watts x 1 chan max power output: 500 watts x 2 chan so bridged, 4 ohms its 500 watts each 12s look here this is the one i have
Kenwood KAC-7205 (kac7205) 1000W 2-Channel Car Amplifier
Op has 4ohm SVC.....Since you want KW get the KAC 9105D, wire to 1ohm. Google search how to wire 2 4ohm DVC to 1ogm. Win.
yup, if op is hard up for KWWhoops ignore the 11am-beer :30 moment.. the 9105D should still be fine 900@1 o 2ohm
That (the part I put in bold in your post) is why I said they will see about 150w each. Your subs are single 4 ohm. Like youve been told, your amp is not stable down to 2 ohms bridged. So, you will need to simply wire one to each channel.but the mono block amp is a one channel amp can i hook it up to push both 12s at 500 watts each i was looking at this one here but its 300W x 1 @ 4 ohms not 500 watts
I totally understand, brother. Just remember, look for rated RMS wattages at 2 ohms for the subs you have.i guess am stuck with this kenwood amp for now but am thinking of buying a different amp which one would you guys suggest to me for a good and powerful amp would realy like to max out theses 2 12s kickers i got
@ quackhead no am not a die hard Kenwood fan saw it and i was told it was not a bad amp so i went with it but no am not a Kenwood fan i wanted a kicker amp or a Rockford Fosgate amp but to much money but am going to stay with this amp for now and save up some more money and buy a better one to many bills right now
