keep Poping amps...help
gotflex
hi all .. right stay with me on this .iv just blown my 3rd amp another one dead ..
1st one vibe 1200w 2 ch
2nd one legacy 2000w 2 ch
3rd legacy 600w 2 ch works but only at half vol ????
system ..in the cab eonon touch 7" hd head unit 1xsub, 1front l+r and rear l+r rca outputs
2 x 5" fusion mids crossovers tweeters 250w
2x 8" mid bass units 200w
running on amps
gto 400w 2 ch amp running 4 6x9s running 2 in series (switched on by rem)
sony explod 1600w 2 ch 2x maystar subs 250w on a
3 mutant mt1207 800w 12" subs in custom enclosure tuned to 33hz
the 3xmutants and the amp running these is the problem .. subs show ..3.8 ohm indavidualy
i had all the positives running back to the amp . and all the negatives from subs to amp (the vibe/bridged) worked fine for a few weeks then it just didnt switch on one day
second amp legacy . was told to run them in series amp+ - + - + - amp which again worked for a few days this time and the amp just fizzled and poped when i was showing off . utter fail
and these sony amps im just confused about . i was told u cant bridge them so again a ran subs in series back to one channel on the amp and it barly moves the sub again aft a day or so it just packed in ...
i do have a split charge system in the van which i have ruled out.
i also have 3 batts in total . 1 under the bonnet 2 in the rear strapped both 590ma leisure battery's deep cycle which charge via . solar panel and split charge system
any help would be awesome in solving my issues if ya unsure just ask . ill post any picks kneaded if it helps . i love my system and me van help me fix it plz ..
right so how do i wire these 3 subs then and what am i looking at £££ for amp to run them properly ... thought the vibe 1200w was class d so was the legacy
I don't know what class they are but I do know there cheap! So get a decent amp that does rated at one ohm and wire it the way you have it now there's not much else you can do with that vc config.
i am planning on replacing these subs like! at some point im on a budget atm
i do have 2 jbl500w dual vc subs i was thinking of just putting them in that box and just sealing it till i can afforded to buy a decent amp .. wht do u think legacy amp is 2 ohm? .
and what is a decent 2000w amp these days it was 10 year ago last time i had a car with proper audio (alpine full system)
B² audio - Sweet like Danish
gotflex
gotflex
(ncle) england
d77543020
