Keep blowing distribution block fuses. help!
CodyMags8
Hey guys, I have an RE Audio DTS-1000.1 and an American Bass 4 channel amp (forget the model number), and I have a distribution block with a 4 gauge input, and 2 4 gauge outputs for each amp. I currently am running 2 100 amp AGU fuses for the distribution block, and I thought the fuses would be plenty big enough for my amps. But I keep blowing the fuse that goes to my monoblock amp. The fuse for the 4 channel is fine. I have the Fierce Audio 4/8 AWG AGU block from Best Buy. Any input to keep my fuse from blowing? Thanks in advance guys!
under the hood I would do say 150 to 200 ... its just for fusing the wire... the block in the back is for the amps.. or just swap out the 80 with the 100.. the 80 will work on that re amp no issues.. that amp might push 700 watts
And i still don't think that a smaller front fuse would cause the larger distro fuses to blow that doesn't make since the small fuse would blow first if that is the case right?
ya ya my bad tho, i really did read over the 4ga in part. i said 200 because i figured 2x 100 amp fuses would break evenly on a 200 ANL fuse on 0ga. 150 at most for on 4 if its even true 4ga
---------- Post added at 02:50 PM ---------- Previous post was at 02:49 PM ----------
a lot of times small strands from the wire connected on the amp frey and might cross with the -
CodyMags8
CodyMags8
Kenosha, WI
audiobaun
