keep battery charged?
Naxis2k1
grade A whiteboy
if i were to run too yellow top batteries how do i keep the seconed one charged?
i have a 81000d and i will be running it at 1ohm so i know it needs lots of current so i figure a nother bat should do the trick how do i keep it charged though?
Get a high output alternator as those cost about 50 bucks more than a Yellow top. I made the mistake of buying a yellow top and it did not due much to my system. Then i bought i H.O. alternator and it worked wonders. I even took the yellow top out and could not notice a difference. Although i decided just to keep it in.
A 2nd battery will not do you any good if you can not keep it charged. If anything it is going to hurt you more then it will help. When you need that much current the only thing that will help is a high output altenator 2nd batteries and caps only store power for use that don't make any if your using more then your making its like trying to drive a car with no gas.
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
alpine99gp
