JVC KD-ADV49 no sound
  • 2
hydedabeast
24
ARIZONA
ill start out with saying i have a Lexus ES300 which has a factory amp well i got a harness for it hook it up to my HU, my HU powers on but no sound at all i also notice that i am hooking up AV cables which indicate REAR and FRONT and still no sound what could be the problem and how would i fix
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Its a Hit or Miss on FB.Market Place for buying any electronics. Pull it and wire it up at the vehicles 12v battery to see if it powers on...
970
hydedabeast
hydedabeast
ARIZONA
x1le
    May 18, 2024
    May 18, 2024
