ngsm13
BSEE
I liked mine off of around 180-200rms per side. Better than the piece of shit DA Hex Set I had...
nG
nG
It's an elemental designs 9.2x amp. 200x2 at 4 ohms. The gain is at about 3/4 I think now. DjDilliodon recommended that much power and it sure powers them very nicely =DWhat kind of amp and specs is that? So they dig them then. I hope the DLS sound better or I will kick myself in the *** //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
I wouldn't trust a breaker. If you are blowing fuses, there is a reason for it. Trip the breaker a few times and its ability to protect the circuit is degraded. You could end up with a bad contact causing a lot of resistance and heat which is a fire hazzard. You could also end up with a breaker that arc welds itself closed and doesn't do its job when you really need it to. IMO for high current situations, fuses are the only way to go.I took a video with it up this evening. A couple of sad things happened though! When CRANKED I blew a fuse on Metallica. I went to the audio shop and got another 80 Amp fuse, put in Brooks and Dunn and blew it again when I had it CRANKED. The shop guy said I should look into a circuit breaker so I plan on heading in tomorrow to have one installed. He said 150 Amp.... sound about right?
