Just not happy with new system...
stockwes
So i recently installed a new system in my car. Here are the specs
2008 Honda Civic
Kenwood x994
Jl Audio 450/4
Image Dynamic CTX65CS in front (150 watt rms channel)
Stock in rear (75 watt rms rear channel)
Concept 1200D
2 RE SE10D4's (1200rms to the pair)
1.3 ft^3 sealed box for the pair
1/0 power wire and big three
JL Audio and Monster cable interconnects
All connections soldered where possible
about 100ft^3 damplifier or raam mat in car
After setting gains how i was told and doing all adjustments to the system, i am still just not happy. The SQ is great, there is just not enough volume, at any of the levels, for my taste. Is there something i may be missing? Or what would be the next upgrade that may make me happier on the volume level?
I was considering selling off the concept amp and getting a JL 1000/1 to match the other amp, would this give me a noticable upgrade? Even though i loose 200 watts?
Also was wondering about going active with my fronts and running rear off hu, would this give me more volume?
Any other suggestions?
Thanks for any help or suggestions.
So i recently installed a new system in my car. Here are the specs2008 Honda Civic
Kenwood x994
Jl Audio 450/4
Concept 1200D
Sigh. No, matching amp brands will not make it louder.
What is lacking loudness?
gains set with dmm, 50hz for the concept, 1khz for the jl to recomended voltages for my impeadence... i have a very expensive volt meter that will tell you when any clipping occurs as well, so i know my hu starts clipping at 33 of 35 on the volume scale so that was where i set my gains from... I tryed turning up them a little more but even the slightest touch sent everything into noticable clipping
As for the volume, i had older, far less powerful systems that seemed to be alot louder, all around.... Like everything is balanced but the volume just needs to go up 5 more clicks or so...
Only thing I trust for setting gains is an o-scope, nothing else. Also where do you have your voltmeter connected??
stockwes
stockwes
Portland
Annnarbor84
