Just making a final check
CHUMCHAL72
Just making sure this works before I go spending my money
If I wire the mono amp to two subs
If I wire the amp to 2 ohm's
The amp is
* Monoblock Class D Car Amplifier
RMS Power Rating (@ 14.4V):
4 ohms: 450 watts x 1 chan.
2 ohms: 900 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
Can I wire it to 2 of these
10" Single 4 Ohm W0v3 Series Subwoofer
Power Handling:
Peak: 600 watts
RMS: 300 watts
If used responsibly, This is one of the best set ups I have seen suggested on here as far as equipment matching. Realistically, playing music, you should choose power above speaker rms rated to get the most out of your system with a clean signal.
Thanks some one else told me if I wire my 2 subas and amp at 2 ohm I'll have 900 watts total and 450 to each I think
He also said I could just turn my gain down
CHUMCHAL72
CHUMCHAL72
Victoria, TX
drockstar
