just got P1000.1
Rockford Fosgate P1000.1?
Outsides or insides of what?
What subs do you have? How many do you have? Dual 1,2,3,4 ohms? Lmk and I might be able to help!
If you have one sub you can wire a dual 4 ohm sub down to 2 ohm.....or 2 dual 2 ohm subs to 2 ohm.... lmk what you have!
i am running a single JL audio 12" W6 V2 D4 sub. i have it wired at 2ohms at the moment. on the amp, there are 2 sets of speaker inputs(A and B). Each set has a + and -. I don't know where to put the speaker wire. the way i have it right now is, i have the postive speaker cable connect to the positive input on the the A side and the negative cable to the negative input on the B side. and i barely get any bass from the sub. just a very small bump.
That's the correct way to wire it. How are the other settings set on the amp? At what position is the HP/AP/LP switch? At what position are the Freq Hz. and Gain dials?
Also, is the headunit set properly? Is there a subwoofer level control in your HU? What is the crossover frequency set at in the HU?
My gain setting is just under 50% and the hertz setting is set low. just about 35hertz. i don't know how to check tlhe freq settin on the headunit. there is no HP/AP/LP switch. there is a infrasonic switch that i can either turn on and off(with a punch eq dial.)
kingkung
kingkung
Huntington Beach, Ca
kingkung
michigan born
    May 14, 2026
michigan born
    May 14, 2026
