Just got new subs, wiring question....
Jimmaaay
Greek Man
Ok I just ordered two 2 ohm dual voice coil woofers and I was wondering to wire then to 2 ohms is this how I should do it. Wire the voice coils in parallel (negative to negative, positive to positive) on both subs. Then wire the positive of sub one to the + on the amp and the negative of the sub two to the negative on the amp? Oh by the way the amp is a mono block amp. Just wanted to to see if this was correct to wire these at 2 ohms.
Thanks, James
Also when I see the wires in the diagram that are connected does that mean I have to wire through the box? Like the positives they are combining into one. I am confused on that part.
its basic stuff parallel cuts the ohm load in half and series increases it
well depends on how you look at it^^
wire the coils on each sub in series (2 + 2) = 4 ohm per sub
then wire each sub in parallel to the amp (4 - 4) = 2 ohms
Yes I have a box with 2 separate chambers. If you look in the diagram for wiring to 2 ohms, the positive from one woofer connects with the positive from the other woofer. It looks like they are connecting. Do you wire between the chambers. The diagram confuses me.
i would help ya and do a "paint" drawing but im too tired. just wire each sub like this...
both pos. to the pos. of the terminal, and both neg. to the neg. of the terminal....
then from the outside of the box. wire one pos. of one terminal to the neg. of the other terminal.
THEN wire the remaining pos and neg of the terminals to the amps pos and neg. respectivly
The part that is confusing me is the part that I circled. The wires connect so do I have to wire the subs between the box, like wire through the wall of the box to the other woofer.
Jimmaaay
Greek Man
Jimmaaay
Concord, CA
Jimmaaay
BP1Fanatic
BP1Fanatic
