dave_damage
Soundstream Nut Swinger
What are your thoughts?
* Power output:
o 140 Watts RMS x 4 @ 4 ohms
o 240 Watts RMS x 4 @ 2 ohms
o 480 Watts RMs x 2 Bridged @ 4 ohms
* Regulated MOSFET power supply
* Proprietary power supply technology
* STACT (stabilized apex current technology) reduces power supply stress by 50%
* Auto high-current, regulates power supply load for application
* Chassis-sink technology transistor placement for optimum thermal transfer
* Triple darlington output circuitry
* Proprietary bass equalization
* Harmonic bass alignment for tighter and accurate bass equalization
* IDI: Intelligent distress indicator provides visual indication of protection status
* Drive delay II eliminates turn-on & turn-off pops
* Ultra-low ESR capacitors for rapid power delivery & dynamic transient peaks
* Built-in-bi-liner crossovers including pre-amp outputs
* 4-way protection topology (thermal, dc offset, direct short & impedance)
* Individually selectable balanced inputs for highest level of noise reduction
* 6dB rear channel de-emphasis @ 7KHZ
* 0-9dB 50-70hz bass boost
* 12dB 13-30hz subsonic filter
* Input selection
* Pre-amp output
* 180 degree phase control
* Damping Factor: 1800
* Signal-to-noise ratio: 99dB
* THD: 0.005%
* Dimensions: 2.75" H x 11.125" W x 22.125" L
* Power output:
* Input selection
* Pre-amp output
* THD: 0.005%
