dave_damage
Soundstream Nut Swinger
Just going by these specs, how would you rate this amp all around. I don't want to say what it is at first to keep things focused on the specs and not the brand.
# Black anodized aluminium finish
# Variable High/Low pass crossover (55 - 550 Hz, 12 dB/Oct)
# Variable bass boost (0 - 18dB @ 45 Hz)
# Adjustable input level controls with ground loop isolation (500mV - 5V)
# PWM MOSFET Power supply with low AM RFI and protection circuits for overheating and sepaker shorts
# RCA Inputs: 2 pair
# Gold-plated input/output connectors and an external automotive type fuse
# Remote turn-on with "soft start" musting to prevent "thump"
# Dimensions: 13" L x 8-1/2" W x 2-1/4" H
# Number of Channels 4
# RMS Power (4 ohms) 57 watts x 4 chan.
# RMS Power (2 ohms) 88 watts x 4 chan.
# RMS Power (1 ohm) Not Stable
# Bridged RMS Power 182 watts x 2 chan.
# Peak Power Output 700 watts approx.
# Min. Impedance Unbridged 2 ohms
# Min. Impedance Bridged 4 ohms
# THD @ Rated RMS Power 0.05%
# Speaker Level Inputs No
# Amp Preamp Outputs No
# Built-in Crossover HP (50 - 550 Hz), LP(55 - 550 Hz)
# Bass Boost 0 - 18 dB
# Signal-to-Noise Ratio 100 dB
# Fan Cooled No
# Fuse Rating 40A
# Fan Cooled No
# Fuse Rating 40A
