way to cover your bases. how many forums did you post on? at least 3. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
do you have to buy it from Best Buy? Can your order one?
You bought a Dual 2 ohm sub. So you need to power it at 1 ohm or 4 ohms. You cannot achieve 2 ohm mono. The amps you listed are not what you want. Glad you got that figured out.
The Phoenix Gold S1000.1 includes high-level inputs and auto turn-on so you don't need to do any wiring behind the head unit or generate a remote turn-on. I recommend this over the two you listed. Phoenix Gold is making a nice come-back. This amp is larger than you need, so you have some future flexibility and headroom so you won't worry about clipping.
S1000.1 - 1000 Watt Mono-Block Amplifier - Phoenix Gold
http://www.phoenixgold.com/products/AMPLIFIERS/S/product.php?productID=1
There are other 1 ohm stable amps you could look at. Or you could get a higher power 2 channel and bridge it. But you want to keep high-level inputs and auto turn-on or you'll need to buy a LOC to achieve that. If you want a LOC and use any 'ol amp, i recommend this one: Navone Engineering N-RHL-2
N-RHL2 - BEST LOC IN THE WORLD!! - $24.95 : Zen Cart!, The Art of E-commerce
http://davidnavone.com/zencart/index.php?main_page=product_info&cPath=1&products_id=1&zenid=278fvnpq81s31v9v884hjn1vr5
don't worry about running amps at 1 ohm when that is what they are rated for. they won't fail any sooner just because of it. in the end, the power you need is MUCH cheaper at 1 ohm. trying to get the power you want at 4 ohm, within your budget, will be challenging. RF is good also.
same response as the other forum(s).
