Just bought 05 kicker DCVR 12 loaded box
Prizm
.. and i decided on the MTX 5601 600W amp to power these
i was wondering can i run this system at 2 ohms so i can get the full 300 watts to each sub? please give any personal opinions on the amp/ subs i have chosen
thanks
dual 4 , do you think i will get enough bass from that amp and if not what do you suggest ? i listen to rap music and want my system to be heard
do you think i will get enough bass from that amp and if not what do you suggest ? i listen to rap music and want my system to pound
hmmm you know what you sould do actually? Get one of the Diamond Audio D5600.2 amps that Bimma85 has for sale. I would take that over the MTX any day. Each sub would be getting 300wrms+, as Diamond Amps are reasonably underrated. You cannot run that setup at 2 ohms...
while I agree the diamond is a great amp and I own 2
I would go with a Dclass with a 1 ohm final rating,maybe a Diamond D3600.1
or similar - I do like the MTX amps alot too,youll have to check the specs for a 1ohm load if avalible
while I agree the diamond is a great amp and I own 2I would go with a Dclass with a 1 ohm rating,maybe a Diamond D3600.1
but i would not be able to run it at 1ohms right? does that make a difference
The diamond amps are of better quality then MTX. With the voice coil setup you have, you can run your system at either 4 ohms or 1 ohm. The D3600.1 amps are great as well, I was sugguesting the D5600.2 because it is a nicer amp, and at Bimma's price it is a lot less money then the 600.1 would be.
interesting, i can really run it at 1ohm .. what would you suggest running it at 1ohm or 4 ?
and are there any benefits of getting a mono channel amp over a 2 channel amp?? just tell me what you would do to get the most power possible on my setup
u wire the subs to a 1ohm load your gonna blow your AMP. see if u could trade your subs in for dual 2 ohm ons. then u can power them up properly with out nuking your amp
Prizm
Prizm
canada
406er
