mastershake
Anyone who offers assistance here i am grateful. i have all the speakers and amps i believe i need but i am unsure of wiring. i have 2 kenwood subs (KFC-XW1225dB 3oo rns 1200 peak) 2 kenwood 7x10's (KFC-X718 i believe rms is 180 cause 360 is max...but thats what the box says so it could be fo e both or just one) and two kenwood 6.5 component speakers for the front (KFC-XR61p 180 max still in box) my amps are one kenwood KAC-X810D (one channel..400-1000 watt rms based on battery performance and ohms) and 1 KAC-X521 2 channel (still in it s box 80x2-250x2 or 320x1-510x1, 1000 peak)
my reciver is the kenwood 969 two piece which i love cause that thing will play all formats and through all scratches. 5.0 preouts and 50x4 max
i have the 810d with an 8 gauge fused two the two subs wired at ohms. i dont think im getting near the performance i want there but dont know how to rewire the sub setup. unsure also if box terminals are affecting performance either i got thr box on ebay for 40$. the 7x10s i had installed at a stero sttire because they had cut a loy of metal b/c gm lists the cavalier with 6x9s but thry are 5x7s. i had them cut the steel because u did want to cut through the back in case ever take them out i have stock look stil. my question here was the stock speakers had a 4 wire pin that hooked into the stock speakers in to a port and the place just clipped those off adn use two wires adn taped the toher two if that would affect enything.
what i really need help on is wiring the 521 amp to the fronts and rear..or if i should go off the 810d to the 7x10s
i relize i will need a distribution block probally and will go a 4 g to the block and ywo 8 s out. its a cavalier to so ill need a cap if u could recomend a decebt one
i can sum money im a full time aerospace ngineer student but all on scolarships i have a 2003 cavalier and i prolly will need up grade the batt if u have an opinion on that. if uve made it this far then thank yo for ur time and i appreciate any help
