Jordon's 2015 mustang
  • 7
jordon
So I've bought all my equipment yesterday. Now just the waiting game. Once I get everything I will upload pics of the equipment. I'll put some pictures of the car soon.
Current equipment:
Stock electrical
Dd m80b
2 Alpine type X 10s
Incriminator audio components
Kenwood mini amp
What's going in
Fsd 2.6K Will be set to clamp between 900 - 1K at shows to stay street stock 1k.
Soundrive 12
Custom box built by stang 2.5 cubic feet tuned to 35
Js 300 amp hairpin alt
Juice box raspberry up front
Ppi 900.4
Alpine pxe-h660
Ppi and alpine dsp will probably go in first. Then the fsd once I get my alt. And the soundrive will go in last once it arrives. Juice box raspberries are on back order so it will also probably be going in same time as the sub.
Don't forget the Big 3 (or more)!
Tuned in //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif take lots of pics!
whats up with that juicebox? it looks cool but i cant find much info on it.swap that PPI900.4 for soemthing better. they dont sound that good.
Care to elaborate on why they don't sound good? I don't think I have ever heard a difference in amps. Found decent reviews on DIYMA. I am looking at buying a Polk D4000.4, which is essentially the same thing from my understanding.
i think hes talking about the car computer?
No the battery.
If installed properly shouldnt really hear to much of a difference in my opinion
Yeah but you know I assume big 3 should be common sense lol.
Plan on it, waiting on my stuff to arrive. The ppi, tech flex, speed wire 4 conductor, voltage meter, rcas and other small stuff should be here today. The sub should be here mid April as well the juice box there on backorder for the raspberries. Alt should be here next weekend. Amp and dsp should be here middle of next week. And stang hasn't given me a time line on the box yet but I'm not worried nor in a hurry being sub is still far out from arriving
Big difference swapping my ppi 900.4 out for a jl g6600 6 channel. Less output because of obvious power reasons but the tweets really came alive, music was much more lifelike, smooth, airy and sparkly in a way that the ppi could never achieve even with all the tuning in the world. The jl barely needed any tuning to sound good and when eq is flat, the jl destroys the ppi in raw SQ. Only thing is, the ppi is much louder and more efficient.
Yeah I plan on swapping out the incriminator for a nice active set in a month or two. So I wanted the power on tap. But I think my dsp should help the ppi sound good. But I'm no expert when it comes to front stages. Where I lack most of my knowledge
[quote name='jordon']Yeah I plan on swapping out the incriminator for a nice active set in a month or two. So I wanted the power on tap. But I think my dsp should help the ppi sound good. But I'm no expert when it comes to front stages. Where I lack most of my knowledge[/QUOTE]
I know @lowcel is running PPI for his SQ setup with a DSP. He may be able to shine some light on how it sounds as well?
Well if there is any issues in sq. Sure it will be within the dsp or speakers placement
unless you understand how class D works its pretty pointless to try to get someone to understand.. they can soud good, no doubt but there are issues that affter the proformance in a full range class D that must be worked out and just filtering it with capactors isnt going to do it..
as compared to the sound stream reference 4.920 the PPI sounds bad honestly..
So we're you saying I shouldnt even install the ppi where you mentioned me? My plan was High level input into the dsp then rcas from dsp to ppi then run the ppi speaker wire to components. Can I still I use the components crossovers or will that make it more difficult? Like I said I lack alot of knowledge when it comes to tuning and dsp.
If you already have it, run it, just know you actually have room for more sq in the future with a higher quality amp. The PPI will get you loud though, enough to easily overpower the sub stage.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Not less power but less channels. Maybe upgraded all around Bose speakers as well.
I may end up buying the new CDT ES-08 Plus and running customspeakerpods.com 8" speaker pod.
23
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
jordon
jordon
Fort Bragg, NC
jordon
