Jmac Please help!!!!
  • 3
TimBugMH10
Okay I need some specs for a sealed box for two Alpine SWR-1240's. I cant tell the size of my trunk right now cause its in the shop but I can tell you that I listen mostly to Rap and R&B and also some alternative. I am also leaning more towards SQ than SPL.
Any help would be appreciated!!
I know Jmac isn't around alot anymore but his last post was on the 16th. How many cubic feet do you suggest for these.
Also I get the car back later today so I will take some measurements.
probably smalll......something around 1-1.25 per, thats if your still looking for sq or spl....otherwise i would go much bigger and ported.
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
269
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
251
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
919
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
TimBugMH10
TimBugMH10
Airdrie Alberta
TimBugMH10
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
