Jmac Please help!!!!
TimBugMH10
Okay I need some specs for a sealed box for two Alpine SWR-1240's. I cant tell the size of my trunk right now cause its in the shop but I can tell you that I listen mostly to Rap and R&B and also some alternative. I am also leaning more towards SQ than SPL.
Any help would be appreciated!!
I know Jmac isn't around alot anymore but his last post was on the 16th. How many cubic feet do you suggest for these.
Also I get the car back later today so I will take some measurements.
probably smalll......something around 1-1.25 per, thats if your still looking for sq or spl....otherwise i would go much bigger and ported.
578
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
461
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
TimBugMH10
TimBugMH10
Airdrie Alberta
TimBugMH10
    May 24, 2024
    May 23, 2024
