JL W312 is smoking!!....literally
rcracer78
This weekend I removed my sinlge JL W312 sealed enclosure from my Yukon to make more room in the cargo area. When i put it back in and turned on the system the sub cutt out. I immediatly turned the system off and checked all my amps, connections and grounds only to discover i accidently hooked up the positive to the negative and the negative to the positve. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif So i corrected the connection.
Now the sub will not come on. if i disconnect the wire and plug it back in it will push for about 30 seconds and turn off. After i tried this several times, i decided to open up the "sealed" enclosure and to my dismay.....smoke everywhere.
Am I screwed? //content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif
Aside from my negligence was the reverse connection the cause of this?
power reversed, or the amp's output(180 phase)
dman: What do you mean by "amp's output(180 phase)"?
srim: it does not make a crunch sound when i push on the cone.
The amp pushing it is a Rockford Fosgate P400-2. Is this amp suppose to provide any kind of reverse poloarity protection to the sub?
If you mean you switche the pos and neg on the speaker wires, that wouldn't hurt the speaker in any way. If you mean you switching the power and grn wires on the amp, that would make the amp smoke, not the sub. I honestly dont know what you did. lol
did you switch power and ground, or the speaker wires + and -?
i reversed the speaker wires. is that a big no no?
MAN!!!!....I REALLY LOVED THAT SUB TOO.//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
rcracer78
rcracer78
La Habra, CA
rcracer78
