JL Audio Subs/Amp question
Evanish
Which JL amp would be best to run two JL Audio 12W0v2-4 ? Would the JL Audio 500/1v2 be overpowering them? I also need to find which JL amp would be best to put a pair of JL Audio XR650-CSi (Components ) on.
get a 500/1(leaves you room to upgrade in future) and a 300/2 if your set on jl. they are a bit expensive but do make solid products. i kinda miss my 1000/1 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I'm just going with JL as this set-up is going into my show truck and it helps to have a fairly good audio set-up to earn some extra points. I currently have a kicker system. But thanks! I might get some 8'' midbass woffers in the future.
Well, you can get a better setup than JL, but it'll probably not be quite as.. showy. Mainly for the fact that judges wouldn't know the other audio products as well.
you probably can get a sundown 1000d or 1200d for the same price as a JL 500/1. Then you would have tons of room to upgrade. Im a big fan of JL subs, but no there amps even though they are quality.
Evanish
Evanish
Ohio
phensway
