jl audio peeps
The new e1800d looks to be a perfect match for the 10" or 12" w7. I wonder what the price will be, I will call my rep. and find out. Will post them tomarrow!! They probably wern't allowed to start producing them until after CES 2004, the CEA usually has somthing to do with it!!!
sounds good. too bad they only showed its rms @ 2ohms.. we'll need to know what it does @ 4ohms in order to see what it does @ 3
Are you talking about the E1800D? They gave the specs at 4 ohms
Rated Power at 12.5 V:
1 x 480 Watts RMS at 4 ohms
1 x 800 Watts RMS at 2 ohms
Input Range: 200 mV - 8 V RMS
THD at rated power: 0.08% at 4 ohms
Signal to Noise Ratio: >90 dB referred to rated power
Frequency Response: 10 Hz - 250 Hz (+0, -1 dB)
Damping Factor: >500 @ 4 ohms / 50 Hz
Dimensions (L x W x H):
15.75" x 9.25" x 2.36" (400 mm x 235 mm x 60 mm)
price 3 billion dollars
that's strange b/c its say this
e1800D: 1066 watts @ 2 ohms
limitkid7
sell wite
limitkid7
GA
farbs93
