JL AUDIO G-MAX opinions
towncarblue
bx
does anyone have this amp?
does it do the power it claims [1200 rms @ 2ohm]?
it uses 4-guage wire instead of 0-guage power connections so im kinda spectical on its power specs!!!
i cant find a review of this amp!!!!
is this amp underrated?
Mono Subwoofer amplifier
RMS Power @ 4 Ohm: 600 watts x 1 at 14.4 volts
RMS Power @ 2 Ohm: 1200 watts x 1 at 14.4 volts
RMS Power @ 4 Ohm: 450 watts x 1 at 12.5 volts
RMS Power @ 2 Ohm: 1200 watts x 2 at 12.5 volts
Differential-balanced inputs
On-board Crossover
Variable low-pass filter (frequency selection from 40-200 Hz)
Pass-through type Preamp Output
Dual mono speaker outputs (Up to 8 AWG wire)
+12 volt and Ground (Up to 4 AWG wire)
+6 dB fixed frequency bass EQ
Optional wired remote bass control (RBC-1)
15.75"L x 9.25"W x 2.50"H
onlinecarstereo.com has one for sell
i know where to buy one and their specs.......
i wanna know if its a good amp, are those specs reliable , does anyone use these in their car?
Probably dragging this thread up from the depths a bit, but if anyone wants to know if this amp is good or not , I'll put my hand up and say I'm quite happy with mine.
I've slightly overloaded my G-max amp with 2x 13TW5 subs (equalling 1.5 ohms) and I haven't had any problems at all with it.
I've used it constantly at moderate levels //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif and it's never kicked up a fuss, plus I've used it twice for a sound off comp and it's done me well on both occasions.
the output I've turned the gains up to on this amp is 53.1 volts A/C unclipped on the speakers terminals using a rock solid flat 12.5VDC input from a D34 Optima, and this has been into a 1.5 ohm load. That works out to around 1880 peak to peak. Using .707 as the RMS ref. it works out to be 1329WRMS that this amp will happy pump out all day into a 1.5ohm load. Not bad for an engine off reading IMO.
towncarblue
towncarblue
bx
benjames
