JL Audio Cleansweep question
Kaos
I'm using a JL Audio Cleansweep to add a JL 300/4 and JL 500/1 to my factory H/U. My question is how do I feed the JL 500/1? I am using the front and rear RCA outputs on the Cleansweep to run the front and rear channels on the JL 300/4. Can I just use a set of RCA "Y" off the rear set of RCA outputs on the Cleansweep to feed both the rear speaker channel of the 300/4 and to feed the sub from the 500/1? Will this work? Will I have any negative effects? What will happen to the 8v output of the Cleansweep when split like this? TIA.
Kaos
Kaos
Coastal N.C.
WrenchGuy
