JL Audio 500/1 amplifier
hotdog34786
JL 500/1 monoblock amp
Hey Car Audio,
I have a JL 500/1 Amp that I am not in need of anymore. It has a few small scratches on it and a chip in one of the fins, doesn't effect performance at all. It works great though. I had it connected to a W6 so it was not pushing the amplifier to hard. This thing is a great amp and I am sad to get rid of it, but I need the money now so it is being sold. Let me know if you would like pictures of it. I was trying to get $250 locally but I will consider selling it for $200 shipped. Here are some specs in case you guys are unfamiliar:
Rated Power: 500 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: 95dB below rated power
Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
Differential-Balanced Input Topology: (1 pair of inputs)
On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ: variable boost up to 15dB
Infrasonic Filter: Fully-Variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual mono speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Brand new & factory sealed
$200 shipped
Regular USPS, faster shipping available if buyer pays for it
Shot at 2012-06-12
Shot at 2012-06-12
hotdog34786
hotdog34786
Orlando, FL
budgetkiller
