JL Audio 500/1 amplifier
hotdog34786
JL 500/1 monoblock amp
Hey Car Audio,
I have a JL 500/1 Amp that I am not in need of anymore. It has a few small scratches on it and a chip in one of the fins, doesn't effect performance at all. It works great though. I had it connected to a W6 so it was not pushing the amplifier to hard. This thing is a great amp and I am sad to get rid of it, but I need the money now so it is being sold. Let me know if you would like pictures of it. I was trying to get $250 locally but I will consider selling it for $200 shipped. Here are some specs in case you guys are unfamiliar:
Rated Power: 500 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: 95dB below rated power
Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
Differential-Balanced Input Topology: (1 pair of inputs)
On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ: variable boost up to 15dB
Infrasonic Filter: Fully-Variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual mono speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Brand new & factory sealed
$200 shipped
Regular USPS, faster shipping available if buyer pays for it
Shot at 2012-06-12
Shot at 2012-06-12
well ill get it over with... if your going to post here you should read the rules. you need pics with your user name and date in the photo or this will be deleted. its like when people sell **** on craigslist without photos...friggin annoying.
not to flame ya bro but this is why we want pics. Before you put pics you just said it has a small chip on it in your description. Now you post pics and we can see lots of scratches and a fin completely broken off. You might want to sell this local or drop your price or go on ebay... just my 2 cents. glws
hotdog34786
hotdog34786
Orlando, FL
budgetkiller
