JL Audio 500/1 $150 shipped!!
AwesomeStranger
JL Audio 500/1
100% working order 8/10 cosmetically. Great amp for the price I'm asking.
$150 shipped. Negotiable, might take trades.
A couple scratches from minor wear and tear, nothing serious. GREAT amp.
Features:
Differential-Balanced Input Topology: (1 pair of Inputs)
On-board Crossover: fully variable (40Hz - 200Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ: parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter: fully-variable 24dB/octave from 15-60Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual Mono Speaker output connections: accepts up to 8ga. wire
+12V and Ground connections: accepts up to 4ga. wire
Specifications:
Rated Power: 500W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
THD at Rated Power:
S/N Ratio: >95dB below rated power
Frequency Response: 5 Hz-500Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm per channel/50 Hz
Input Range: switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
Would love some 1/0 wire for the big three + cash if possible. I feel like this is a great price for this real solid amp, if it doesn't sell here I'll sell it on ebay. They are going for $160-175 on there same condition, + 15 shipping so $150 shipped is a killer deal. Would really like a SAZ-1500d for this + cash. I also have a hifonics brutus 1200 amp I could throw in for a saz-1500d.
The amp will fit in the large or medium thin USPS flat rate box. I don't remember which because I received my old 500/1 in it so shipping to hawaii I think is the same cost.
hmm...I have lots of 1/0 OFC, what kind of length are you looking for? And how much cash? Wouldn't mind running this amp to my 12w6v2
AwesomeStranger
AwesomeStranger
Hickory, NC
audiobaun
michigan born
    May 14, 2026
michigan born
    May 14, 2026
