What you think?
12000W in 12.6V - 18kW+ 15V or more - 1ohm
9600W in 2 ohms at 12.6V
Works down to 7.5V and up to 18V ( holds 20V charging)
Again, you can have a voltage drop down to 7.5V and the amp is working.
CLIPPING LED: You dont need any scope for clipping monitoring, the LED flashes when you have the same voltage at power supply and output, on other words, when you have clipped output wave.
LOW Voltage Warning: When the input voltage reaches 9.5V the RED LED flashes
Full Range - 10Hz to 15kHz
SUBSONIC FILTER: 10Hz to 80Hz adjustable
LOW PASS FILTER: From 15kHz to 80Hz
STRAPPABLE: You connect a linking cable between 2 amps, then you control both amps through the amp you connected the RCA cable. 24kW in 12.6V from the amps linked
SIZE: 27.55 x 13 x 2.95 inches
