JL Audio 300/4 4-Channel Amplifier
gringo7718
FL
JL AUDIO 300/4
JL Audio 4-Channel Amplifier in good condition. Works great and sounds even better. It has some minor scratches and some paint chipping off of one of the heat sinks, but it is only cosmetic. I would give it an 8 out of 10 only because of the paint off heat sink.
Rated Power (stereo): 75W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged): 150W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power:
S/N Ratio*: >108.5 dB below rated power
Frequency Response: 5 Hz-30 KHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch./50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
$175 shipped in the continental US
I am located in Miami, FL if you are local.
You can also reach me at gringo7718@hotmail.com
gringo7718
gringo7718
FL
Flex68
