JL Audio 300/2 - Upgrade to 250/1 or 500/1
james33440
FL
I recently installed a JL Audio 12w3v2 along with a JL Audio 300/2 amp in my wife's Navigator. I couldn't pass up on the deal from eBay.
The output sounds decent. Although, some songs sound better than others. I may get an Epicenter or Bass Cube in the future. I may even try a ported box. This sub came in a sealed box.
Anyway, right now I have the 300/2 bridged @ 4-ohm. The sub seems to be taking it with ease.
Should I swap to a JL Audio 500/1 or even the 250/1 amp?
Again, I may go with a ported box but right now, would I notice an audible difference in swapping the 300/2 that I have now to a 500/1 or even a 250/1?
A ported box would probably give more output than switching to a 500.1 Don't bother with a 250.1 it puts out less than the 300.2 bridged. If you want a dramatic difference, switch to ported and the 500.1. But the 300.2 and ported would be much louder than your current setup.
Well except for the fact that the 250/1 is designed for sub duty and the 300/2 isn't hardly...
So are you suggesting that the 250/1 would be better than the 300/2?
Thats why they have these wonderful things called crossovers! Ive used full range amps as bass amps many times.
I have too, that doesn't make it better for the job, though. Bridged @ 4ohm Class A/B vs 4 ohm single channel limited bandwidth Class D, which runs cooler? You're also talking a difference in power of well less than 1dB. I'd take the little mono amp all day and move the other to my front stage.
I think I will go ported and then get a 500/1. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
A Link would be very helpful. Id be interested in taking a look at some gear
250
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
365
james33440
james33440
FL
james33440
