JL Audio 1000/1 Problems
Check your ground. I have the same amp and mine would cut in and out sporadically. Took it apart and everything, checked the ground last and I should have checked it first. Worked fine after that.
Hey all. I took the amp to the local car audio shop and had it tested. The subs were blown and the amp went into protection mode. It was too much power for those little subs. But The amp does work AND I got a refund from the seller for $550. So I only paid around $100 for the amp.
I did purchase a new one (the black special edition 1000/1 - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=300132741859&ssPageName=STRK:MEWN:IT&ih=020 )
So basically I got 2 1000/1 amps for about $700.
I was thinking about getting 2 12w6v2 in a JL Custom ported box. Im not sure what to do with the whole amp thing though. Could I hook both of the amps up to the subs like one amp per sub or would that be too much?
RamenNoodles
RamenNoodles
Baltimore, MD
RamenNoodles
michigan born
    May 14, 2026
michigan born
    May 14, 2026
